      volume move trigger-cutover
Trigger cutover of a move job
This command causes a replicating or deferred volume move job to attempt cutover. Unless the force option is set, cutover entry is not guaranteed.
-vserver <vserver name>- Vserver Name-
The Vserver on which the volume is located.
 -volume <volume name>- Volume Name-
The volume that is being moved.
 [-force <true>]- Force Cutover-
If this parameter is specified, the cutover is done without confirming the operation - even if the operation could cause client I/O disruptions.
cluster1::> volume move trigger-cutover -vserver vs0 -volume testvol_1 -force
