vserver locks show
Display current list of locks
The vserver locks show
command displays information about locks. A lock is a synchronization mechanism for enforcing limits on concurrent access to files where many clients can be accessing the same file at the same time. The command output depends on the parameter or parameters specified with the command. If you do not specify any parameters, the command displays the following information about locks:
Vserver name
Volume name
Object path
Logical interface name
Lock protocol
Lock type
Client
The vserver locks show command is also used to display FlexCache specific locks. FlexCache locks are not stored on the FlexCache volume. Instead all of the locks are stored on the origin of a FlexCache volume. To view the FlexCache locks use the vserver locks show command on the origin cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-smb-attrs ]
If you specify the
-smb-attrs
parameter, the command displays information related to SMB2 and higher. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. - {
[-vserver <vserver name>]
- Vserver -
If you specify this parameter, the command displays information about locks on the specified Vserver.
[-volume <volume name>]
- Volume-
If you specify this parameter, the command displays information about locks on the specified volume.
For the FlexCache locks, this parameter displays the origin of a FlexCache volume name. [-lif <lif-name>]
- Logical Interface-
If you specify this parameter, the command displays information about locks established through the specified logical interface name.
For the FlexCache locks, this parameter is unset if the FlexCache volume is not local to the cluster. [-lif-id <integer>]
- Logical Interface ID-
If you specify this parameter, the command displays information about locks established through the specified logical interface id.
For the FlexCache locks, this parameter displays the logical interface id of the FlexCache cluster. [-path <text>]
- Object Path-
If you specify this parameter, the command displays information about locks at the specified path name.
[-lockid <UUID>]
- Lock UUID } -
If you specify this parameter, the command displays information about the lock with the specified universally unique identifier (UUID).
[-is-constituent {true|false}]
- Is Constituent Volume-
If you specify this parameter, the command displays information only about volumes that either are or are not constituents of a FlexGroup, depending on the value provided.
[-protocol <lock protocol>]
- Lock Protocol-
If you specify this parameter, the command displays information about locks established through the specified protocol. Some of the valid protocols are:
cifs
: SMB locks -
nlm
: NFS3 locks -
nfsv4
: NFS4.0 locks -
nfsv4.1
: NFS4.1 locks -
crposix
: CrPosix locks for CREATE and LINK -
fcache
: Delegations for 7-mode destination FlexCache volumes
[-type {byte-range|share-level|op-lock|delegation}]
- Lock Type-
If you specify this parameter, the command displays information about locks of the specified lock type. The four types of locks are:
Byte-range locks: Lock only a portion of a file.
Share locks: Represent opened files.
Opportunistic locks: Control client-side caching over SMB.
Delegations: Control client-side caching over NFSv4.
[-node <nodename>]
- Node Holding Lock State-
If you specify this parameter, the command displays information about all locks on the specified node.
[-lock-state <lock_state>]
- Lock State-
If you specify this parameter, the command displays information about the state of the lock. Some of the valid states are:
granted
: The lock is established. -
revoking
: The server is currently coordinating with the client to change the state of this lock. -
revoked
: The lock is undergoing revocation to be downgraded or released. -
adjusted
: The lock is undergoing revocation to be replaced by a lock equal to or weaker than the current lock. -
subsumed
: The lock is one of a set of locks that will replace a lock that is being revoked. -
waiting
: The lock is waiting to be granted, because it conflicts with another lock. -
denied
: The lock has been denied. -
timeout
: The lock was waiting and has now timed out. -
gone
: The lock is about to be released. -
unused
: The lock is allocated but has not been processed into any state.
[-bytelock-offset <integer>]
- Bytelock Starting Offset-
If you specify this parameter, the command displays information about bytelocks with the specified offset value. This is the index in the file (in bytes) where the lock begins.
[-bytelock-length <integer>]
- Number of Bytes Locked-
If you specify this parameter, the command displays information about bytelocks with the specified length. This is the number of bytes that are locked by this particular lock.
[-bytelock-mandatory {true|false}]
- Bytelock is Mandatory-
If you specify this parameter, the command displays information only about mandatory bytelocks. A mandatory bytelock enforces the requirement of byte range locking on clients before accessing the associated range.
[-bytelock-exclusive {true|false}]
- Bytelock is Exclusive-
If you specify this parameter, the command displays information only about exclusive bytelocks. When an exclusive bytelock is granted, no other bytelock may be granted whose range overlaps it.
[-bytelock-super {true|false}]
- Bytelock is Superlock-
If you specify this parameter, the command displays information only about super-bytelocks. When a super-bytelock is granted, all other locks on that file are released, and no other operations will be allowed on that file.
[-bytelock-soft {true|false}]
- Bytelock is Soft-
If you specify this parameter, the command displays information only about softened bytelocks. An NFSv4 bytelock might become softened if the connection to the client is interrupted. Soft locks might be reclaimed if the client reconnects. However if another client requests a lock that conflicts with a soft lock, then the soft lock will be released.
[-oplock-level {exclusive|level2|batch|null|read-batch}]
- Oplock Level-
If you specify this parameter, the command displays information about locks with the specified oplock level. The oplock level determines which operations the client may cache locally. Those operations include opening, reading, writing, closing, and creating and destroying bytelocks on a file. The five valid oplock levels are:
batch
: The client may cache all operations on the file. -
exclusive
: The client may cache reads and writes on the file. -
read-batch
: The client may cache reads and opens on the file. -
level2
: The client may cache reads on the file. -
null
: The client may not cache any operations on the file.
[-sharelock-mode <share lock mode>]
- Shared Lock Access Mode-
If you specify this parameter, the command displays information about locks with the specified sharelock mode. The parameter has two components separated by a hyphen: the access mode followed by the share mode. The access mode specifies which operations the client is allowed to perform on the file. The share mode specifies which operations other clients are disallowed to perform. The two modes are a combination of one or more of these permissions:
read
write
delete
all
none
For example, the sharelock mode
read_write-deny_delete
allows the client to read and write the file, and disallows other clients to delete the file. A special mode isdelete-on-close
, which specifies that the server will delete the file as soon as it is closed. -
[-sharelock-soft {true|false}]
- Shared Lock is Soft-
If you specify this parameter, the command displays information only about softened sharelocks. A NFSv4 sharelock can become softened when the connection to the client is interrupted. If the client reconnects, it might reclaim the sharelock. However, if another client creates a sharelock that conflicts with the softened sharelock, the softened sharelock will be released.
[-delegation-type {read|write}]
- Delegation Type-
If you specify this parameter, the command displays information only about locks with the specified delegation-type setting. The delegation type determines which operations the client may cache locally. The two valid delegation types are:
read
write
[-owner-id <text>]
- Owner ID-
If you specify this parameter, the command displays information only about locks with the specified owner ID. The owner ID is an opaque byte string generated by the server for each file lock request.
[-client-address <IP Address>]
- Client Address-
If you specify this parameter, the command displays information only about locks from the specified client IP address.
[-client-address-type {ipv4|ipv6|ipv6z}]
- Client Address Type-
If you specify this parameter, the command displays information only about locks corresponding to a certain IP address type. Please note that locks created over the NFSv4 or NFSv4.1 protocol cannot have their address types resolved. Valid options are:
ipv4
: Clients operating over an IPv4 interface. -
ipv6
: Clients operating over an IPv6 interface.
[-smb-open-type {none|durable|persistent}]
- SMB Open Type-
If you specify this parameter, the command displays information only about locks with the specified SMB open type. Valid open types are
durable
: Durability is a feature of SMB2. A durable lock might become "disconnected" if the connection between the client and server is disrupted. A disconnected durable lock might be reconnected if the connection is reestablished. -
persistent
: Persistence is a feature of SMB3. Persistent locks can become disconnected and later reconnected, like durable locks. Persistent locks are used to facilitate continuously available shares. -
none
: The lock is neither durable nor persistent.
[-smb-connect-state <Lock Connect State>]
- SMB Connect State-
If you specify this parameter, the command displays information only about locks with the specified SMB connection state. Some of the valid states are:
connected
: This is the normal state of a SMB lock when the server and client are connected. -
disconnected
: If a lock is durable or persistent, it might become disconnected if the connection between the server and its client is interrupted. Disconnected locks may later be reconnected if the connection is reestablished.
[-smb-expiration-time <integer>]
- SMB Expiration Time (Secs)-
If you specify this parameter, the command displays information only about locks with the specified SMB lock expiration time. When a lock is disconnected,
shows the time remaining until the lock expires. The server releases the lock after it expires. [-smb-open-group-id <text>]
- SMB Open Group ID-
If you specify this parameter, the command displays information only about locks with the specified SMB open group identifier. This is an opaque byte string provided by the client as the SMB lease key when the lock is first established.
[-is-flexcache-lock {true|false}]
- Is FlexCache Lock-
If you specify this parameter, the command displays information only about locks with the specified value.
[-flexcache-volume <text>]
- FlexCache Volume Name-
If you specify this parameter, the command displays information only about locks with the specified FlexCache volume.
[-flexcache-vserver <text>]
- FlexCache Vserver Name-
If you specify this parameter, the command displays information only about locks with the specified Vserver hosting a FlexCache volume.
[-flexcache-vserver-uuid <UUID>]
- FlexCache Vserver UUID-
If you specify this parameter, the command displays information only about locks with the specified UUID of a Vserver hosting a FlexCache volume.
[-flexcache-volume-msid <integer>]
- FlexCache Volume MSID-
If you specify this parameter, the command displays information only about locks with the specified FlexCache volume MSID
[-flexcache-cluster <text>]
- FlexCache Cluster Name-
If you specify this parameter, the command displays information only about locks with the specified cluster hosting a FlexCache volume.
[-flexcache-lock-authority <text>]
- FlexCache lock authority-
If you specify this parameter, the command displays information only about locks with the specified authority granted to a FlexCache volume.
The following example displays default information about all locks:
cluster1::> vserver locks show Vserver: vs0 Volume Object Path LIF Protocol Lock Type Client -------- ------------------------- ----------- --------- ----------- ---------- vol1 /vol1/notes.txt node1_data1 cifs share-level 192.168.1.5 Sharelock Mode: read_write-deny_delete op-lock 192.168.1.5 Oplock Level: read-batch /vol1/notes1.txt node1_data1 cifs share-level 192.168.1.5 Sharelock Mode: read_write-deny_delete op-lock 192.168.1.5 Oplock Level: batch /vol1 node1_data2 cifs share-level 192.168.1.5 Sharelock Mode: read-deny_delete /vol1/notes.txt node1_data2 cifs share-level 192.168.1.5 Sharelock Mode: read_write-deny_delete op-lock 192.168.1.5 Oplock Level: read-batch 7 entries were displayed.
The following example displays the SMB related information about all locks:
cluster1::> vserver locks show -smb-attrs Vserver: vs0 Volume Object Path LIF Protocol Lock Type Client -------- ------------------------- ----------- --------- ----------- ---------- vol1 /vol1/notes.txt node1_data1 cifs share-level 192.168.1.5 Sharelock Mode: read_write-deny_delete Open Type: durable Connect State: connected Expiration Time (Secs): - Open Group ID: 625e2ff46ee5df1194ba0050569d37047058909c00000000873d210700000000 op-lock 192.168.1.5 Oplock Level: read-batch Open Type: - Connect State: connected Expiration Time (Secs): - Open Group ID: 625e2ff46ee5df1194ba0050569d37047058909c00000000873d210700000000 /vol1/notes1.txt node1_data1 cifs share-level 192.168.1.5 Sharelock Mode: read_write-deny_delete Open Type: durable Connect State: connected Expiration Time (Secs): - Open Group ID: 625e2ff46ee5df1194ba0050569d370440fc8891000000005a3f210700000000 op-lock 192.168.1.5 Oplock Level: batch Open Type: - Connect State: connected Expiration Time (Secs): - Open Group ID: 625e2ff46ee5df1194ba0050569d370440fc8891000000005a3f210700000000 /vol1 node1_data2 cifs share-level 192.168.1.5 Sharelock Mode: read-deny_delete Open Type: none Connect State: connected Expiration Time (Secs): - Open Group ID: - /vol1/notes.txt node1_data2 cifs share-level 192.168.1.5 Sharelock Mode: read_write-deny_delete Open Type: durable Connect State: connected Expiration Time (Secs): - Open Group ID: 625e2ff46ee5df1194ba0050569d370408e08d9c00000000da40210700000000 op-lock 192.168.1.5 Oplock Level: read-batch Open Type: - Connect State: connected Expiration Time (Secs): - Open Group ID: 625e2ff46ee5df1194ba0050569d370408e08d9c00000000da40210700000000 7 entries were displayed.
The following example displays default information about all locks in list form:
cluster1::> vserver locks show -instance Vserver: vs0 Volume: vol1 Logical Interface: node1_data1 Object Path: /vol1/notes.txt Lock UUID: 447db184-f801-11df-8bb5-00a098000e34 Lock Protocol: cifs Lock Type: share-level Node Holding Lock State: node1 Lock State: granted Bytelock Starting Offset: - Number of Bytes Locked: - Bytelock is Mandatory: - Bytelock is Exclusive: - Bytelock is Superlock: - Bytelock is Soft: - Oplock Level: - Shared Lock Access Mode: read_write-deny_delete Shared Lock is Soft: false Delegation Type: - Client Address: 192.168.1.5 Client Address Type: ipv4 SMB Open Type: durable SMB Connect State: connected SMB Expiration Time (Secs): - SMB Open Group ID: 625e2ff46ee5df1194ba0050569d37047058909c00000000873d2107000000004 Vserver: vs0 Volume: vol1 Logical Interface: node1_data1 Object Path: /vol1/notes.txt Lock UUID: 447db185-f801-11df-8bb5-00a098000e34 Lock Protocol: cifs Lock Type: op-lock Node Holding Lock State: node1 Lock State: granted Bytelock Starting Offset: - Number of Bytes Locked: - Bytelock is Mandatory: - Bytelock is Exclusive: - Bytelock is Superlock: - Bytelock is Soft: - Oplock Level: read-batch Shared Lock Access Mode: - Shared Lock is Soft: - Delegation Type: - Client Address: 192.168.1.5 Client Address Type: ipv4 SMB Open Type: - SMB Connect State: connected SMB Expiration Time (Secs): - SMB Open Group ID: 625e2ff46ee5df1194ba0050569d37047058909c00000000873d210700000000 Vserver: vs0 Volume: vol1 Logical Interface: node1_data1 Object Path: /vol1/notes1.txt Lock UUID: 48cee334-f801-11df-8bb5-00a098000e34 Lock Protocol: cifs Lock Type: share-level Node Holding Lock State: node1 Lock State: granted Bytelock Starting Offset: - Number of Bytes Locked: - Bytelock is Mandatory: - Bytelock is Exclusive: - Bytelock is Superlock: - Bytelock is Soft: - Oplock Level: - Shared Lock Access Mode: read_write-deny_delete Shared Lock is Soft: false Delegation Type: - Client Address: 192.168.1.5 Client Address Type: ipv4 SMB Open Type: durable SMB Connect State: connected SMB Expiration Time (Secs): - SMB Open Group ID: 625e2ff46ee5df1194ba0050569d370440fc8891000000005a3f210700000000 3 entries were displayed.
The following example displays the FlexCache locks:
cluster1::> vserver locks show Vserver: vs34 Volume Object Path LIF Protocol Lock Type Client -------- ------------------------- ----------- --------- ----------- ---------- origin /origin/file1 data1 nlm byte-range 10.235.224.139 Bytelock Offset(Length): 0 (18446744073709551615) /origin/file3 data1 nlm byte-range 10.234.133.121 Bytelock Offset(Length): 0 (18446744073709551615) FlexCache Lock: true /origin/file2 - nlm byte-range 10.234.189.144 Bytelock Offset(Length): 0 (18446744073709551615) FlexCache Lock: true 3 entries were displayed. cluster1::> vserver locks show -fields flexcache-vserver, flexcache-volume, flexcache-cluster vserver volume lif path flexcache-volume flexcache-vserver flexcache-cluster ------- ------ ----- ------------- ---------------- ----------------- ----------------- vs34 origin data1 /origin/file1 - - - vs34 origin data1 /origin/file3 local_fc vs34 cluster2 vs34 origin - /origin/file2 fc1 vs12 cluster1 3 entries were displayed.
The following example displays default information about FlexCache and origin of FlexCache locks in list form:
cluster1::> vserver locks show -instance Vserver: vs34 Volume: origin Logical Interface: data1 Object Path: /origin/file1 Lock UUID: 173d10d6-f64c-4983-a2c2-9db0bc4f5c05 Is Constituent Volume: false Lock Protocol: nlm Lock Type: byte-range Node Holding Lock State: node1 Lock State: granted Bytelock Starting Offset: 0 Number of Bytes Locked: 18446744073709551615 Bytelock is Mandatory: false Bytelock is Exclusive: false Bytelock is Superlock: false Bytelock is Soft: false Oplock Level: - Shared Lock Access Mode: - Shared Lock is Soft: - Delegation Type: - Owner ID: 31-113439407363737072303435323636363030312e67646c2e656e676c61622e6e65746170 Client Address: 10.235.224.139 Client Address Type: ipv4 SMB Open Type: - SMB Connect State: - SMB Expiration Time (Secs): - SMB Open Group ID: - Is FlexCache Lock: - FlexCache Volume Name: - FlexCache Vserver Name: - FlexCache Vserver UUID: - FlexCache Volume MSID: - FlexCache Cluster Name: - Vserver: vs34 Volume: origin Logical Interface: data1 Object Path: /origin/file3 Lock UUID: e3bf0c78-7371-41b6-9eff-4fa81d64ca08 Is Constituent Volume: false Lock Protocol: nlm Lock Type: byte-range Node Holding Lock State: node1 Lock State: granted Bytelock Starting Offset: 0 Number of Bytes Locked: 18446744073709551615 Bytelock is Mandatory: false Bytelock is Exclusive: false Bytelock is Superlock: false Bytelock is Soft: false Oplock Level: - Shared Lock Access Mode: - Shared Lock is Soft: - Delegation Type: - Owner ID: 25-11333740736373707230343934343331303031 Client Address: 10.234.133.121 Client Address Type: ipv4 SMB Open Type: - SMB Connect State: - SMB Expiration Time (Secs): - SMB Open Group ID: - Is FlexCache Lock: true FlexCache Volume Name: local_fc FlexCache Vserver Name: vs34 FlexCache Vserver UUID: 388e3004-7520-11e8-8789-005056b47572 FlexCache Volume MSID: 2160150696 FlexCache Cluster Name: cluster2 Vserver: vs34 Volume: origin Logical Interface: - Object Path: /origin/file2 Lock UUID: c420b002-d78c-4157-94d5-55c186ef4df3 Is Constituent Volume: false Lock Protocol: nlm Lock Type: byte-range Node Holding Lock State: node1 Lock State: granted Bytelock Starting Offset: 0 Number of Bytes Locked: 18446744073709551615 Bytelock is Mandatory: false Bytelock is Exclusive: false Bytelock is Superlock: false Bytelock is Soft: false Oplock Level: - Shared Lock Access Mode: - Shared Lock is Soft: - Delegation Type: - Owner ID: 32-11353040736373707230343532363634303031 Client Address: 10.234.189.144 Client Address Type: ipv4 SMB Open Type: - SMB Connect State: - SMB Expiration Time (Secs): - SMB Open Group ID: - Is FlexCache Lock: true FlexCache Volume Name: fc1 FlexCache Vserver Name: vs12 FlexCache Vserver UUID: 5a943dd9-7520-11e8-b5e7-005056b47786 FlexCache Volume MSID: 2150871844 FlexCache Cluster Name: cluster1 3 entries were displayed.
