snapmirror mediator add
Create mediator config entry
The snapmirror mediator add command configures the connection between a pair of clusters and a mediator. This configuration is used only when a pair of clusters have SnapMirror relationships of type AutomatedFailOver.
-mediator-address <IP Address>- Mediator Ip Address-
Specifies the IP address of the mediator.
-peer-cluster <text>- Peer cluster-
Peer cluster with AutomatedFailOver SnapMirror relationships.
-username <text>- Username-
User account at the mediator.
[-port-number <integer>]- Port Number-
This optional parameter specifies the mediator service port number to communicate with the mediator. The port number must be in the range 1025 to 65535 inclusive. The default port number is 31784.
The following example configures the connection between a mediator and a pair of clusters.
clusA::> snapmirror mediator add -mediator-address 10.234.102.227 -peer-cluster clusB -username admin
Notice: Enter the mediator password.
Enter the password:
Enter the password again:
Info: [Job: 114] 'mediator add' job queued
