lun igroup add
Add initiators to an initiator group
This command adds initiators to an existing initiator group (igroup). You can add an initiator to an initiator group only if there are no LUN mapping conflicts. Mapping conflicts occur when an initiator is already paired with a LUN. If you attempt to run this command and there are LUN mapping conflicts, the command returns an error.
An initiator cannot be a member of two igroups of different OS types. For example, if you have an initiator that belongs to a Solaris igroup, the command does not allow you to add this initiator to an AIX igroup.
When you add FCP initiators, you can specify an alias instead of the initiator’s World Wide Port Name (WWPN) or the iSCSI Qualified name (IQN).
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-igroup <text>
- Igroup Name-
Specifies the initiator group to which you want to add a new initiator.
-initiator <text>,…
- Initiators-
Specifies the initiator that you want to add. You can specify the WWPN, IQN, or alias of the initiator.
cluster1::> lun igroup add -vserver vs1 -igroup ig1 -initiator iqn.1992-08.com.mv.mvinitiator
Adds the initiator iqn.1992-08.com.mv.mvinitiator to the initiator group ig1 on Vserver vs1.
