metrocluster modify
Modify MetroCluster configuration options
The metrocluster modify
command modifies MetroCluster parameters for nodes in the MetroCluster configuration.
-auto-switchover-failure-domain <MetroCluster AUSO Failure Domain>
- Cluster Level AUSO Option -
This parameter specifies the configuration of automatic switchover. Modifying
is not supported on a MetroCluster over IP configuration.The parameter values are:
auso-on-cluster-disaster - triggers an unplanned switchover if all nodes in a DR cluster are down.
auso-on-dr-group-disaster - triggers an unplanned switchover if both nodes of a DR group are down.
auso-disabled - automatic switchover is disabled.
On a MetroCluster over IP configuration,
is set toauso-disabled
; otherwise, it is set toauso-on-cluster-disaster
.A change to the parameter affects only the local cluster where the
metrocluster modify
command is used. -
-enable-unmirrored-aggr-deployment {true|false}
- Enable or Disable Unmirrored Aggregate Deployment -
Enable or disable unmirrored aggregates deployment
-node-name {<nodename>|local}
- Node to Change the Option On } -
This parameter is used to specify the node in the cluster for which the parameter needs to be modified.
[-automatic-switchover-onfailure <true>]
- Node Level AUSO Option (privilege: advanced) }-
This parameter is used to enable automatic switchover on node failures. The
parameter is not supported on a MetroCluster over IP configuration.All nodes in a MetroCluster configuration must have this option enabled to enable automatic switchover on failure.
The following example shows the output of Metrocluster modification done on a node:
clusA::*> metrocluster modify -node-name clusA-01 -node-object-limit on [Job 168] Job succeeded: Modify is successful clusA::*> metrocluster modify -node-name clusA-01 -automatic-switchover-onfailure false [Job 308] Job succeeded: Modify is successful clusA::> metrocluster modify -auto-switchover-failure-domain auso-on-cluster-disaster [Job 308] Job succeeded: Modify is successful
