      security session limit vserver delete
Delete per-vserver session limit
This command allows deletion of a per-Vserver management session limit. The "Cluster" vserver is used when the specific Vserver doesn't have a configured limit.
- -interface {cli|ontapi|rest}- Interface (privilege: advanced)
The interface (CLI, ONTAPI, or REST) to which the limit applies.
- -vserver <vserver>- Vserver (privilege: advanced)
The specified Vserver to which this limit applies. The "Cluster" Vserver is used to limit Vservers that do not have a configured limit.
The following example illustrates deleting all per-Vserver limits for management sessions except the default limit.
cluster1::*> security session limit vserver delete -interface * -vserver !Cluster 1 entries was deleted.
 PDFs
PDFs
