ONTAP 9.8 commands
lun delete
Delete the LUN
This command deletes a LUN from a specified Vserver and volume. If the LUN is mapped and online, the force option is required to delete it.
If a LUN is mapped to an initiator group, you can unmap it by using the lun unmap command. If a LUN is online, you take it offline by using the lun offline command.
Note If you create a LUN from a file, you cannot remove the file while the LUN is linked to it. If you want to remove the file, you must first delete the LUN.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
{ -path <path> - LUN Path
Specifies the path of the LUN you want to delete. Examples of correct LUN paths are /vol/vol1/lun1 and /vol/vol1/qtree1/lun1 .
| -volume <volume name> - Volume Name
Specifies the volume that contains the LUN you want to delete.
[-qtree <qtree name>] - Qtree Name
Specifies the qtree that contains the LUN you want to delete.
-lun <text> - LUN Name }
Specifies the LUN that you want to delete.
[-f, -force <true>] - Force Deletion of an Online and Mapped LUN
Force deletion of an online LUN that is mapped to an initiator group.
[-force-fenced <true>] - Force Deletion of a Fenced LUN
Force deletion of a LUN that is currently fenced.
cluster1::> lun delete -vserver vs1 -path /vol/vol1/lun1
Deletes the LUN at path /vol/vol1/lun1 on Vserver vs1.
