storage automated-working-set-analyzer start
Command to start Automated Working Set Analyzer on node or aggregate
The automated-working-set-analyzer start command enables the Automated Workload Analyzer that is capable of doing the following:
  • Flash Pool modeling for an aggregate
  • Flash Cache modeling for a node - can not specify an aggregate.
  • Working set size estimation
  • Workload monitoring
-node <nodename> - Node Name (privilege: advanced)
This parameter indicates the node name that the AWA instance runs on.
[-flash-cache {true|false}] - Flash Cache Node-wide Modeling (privilege: advanced)
This parameter indicates whether the AWA is modeling flash-cache.
[-aggregate <aggregate name>] - Aggregate (privilege: advanced)
This parameter indicates the aggregate name that the AWA instance runs on.
[-working-set-size {true|false}] - Working Set Size (privilege: advanced)
This parameter indicates whether the AWA instance is configured to find the working set size.
cluster1::> storage automated-working-set-analyzer start -node vsim1 -aggregate aggr0
