The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver cifs home-directory search-path add
PDF of this doc site
Creating your file...
Your file is ready
Add a home directory search path
The vserver cifs home-directory search-path add
command adds a search path to a CIFS home directory configuration.
-vserver <vserver name>
- Vserver-
This parameter specifies the CIFS-enabled Vserver containing the CIFS home directory configuration to which you want to add the search path.
-path <text>
- Path-
This parameter specifies the search path you want to add.
The following example adds the path /home1 to the CIFS home directory configuration on Vserver vs1.
cluster1::> vserver cifs home-directory search-path add -vserver vs1 -path /home1
