ONTAP 9.8 commands
lun move-in-volume
Move a LUN within a volume
This command moves a LUN to a new path in the same volume or renames a LUN. If you are organizing LUNs in a qtree, the command moves a LUN from one qtree to another. You can perform a LUN move while the LUN is online and serving data. The process is non-disruptive. Use the lun move start command to move a LUN to a different volume within the same Vserver.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver.
{ -path <path> - LUN Path
Specifies the path of the LUN you want to move. Examples of correct LUN paths are /vol/vol1/lun1 and /vol/vol1/qtree1/lun1 .
| -volume <volume name> - Volume Name
Specifies the volume of the LUN you want to move.
[-qtree <qtree name>] - Qtree Name
Specifies the qtree of the LUN you want to move.
-lun <text> - LUN Name }
Specifies the name of the LUN that you want to move.
{ -new-path <path> - New LUN Path
Specifies the new path of the LUN. Examples of correct LUN paths are /vol/vol1/lun1 and /vol/vol1/qtree1/lun1 .
| [-new-qtree <qtree name>] - New Qtree Name
Specifies the new qtree name that you want to move the LUN to.
-new-lun <text> - New LUN Name }
Specifies the new name of the LUN.
cluster1::> lun move-in-volume -vserver vs1 -volume vol1 -lun lun1 -new-lun newlun1
Renames lun1 to newlun1 on Vserver vs1 and volume vol1 .
cluster1::> lun show -vserver vs1 -volume vol1
server   Path                            State   Mapped   Type         Size
s1       /vol/vol1/A/lun1                online  mapped   linux        10MB
luster1::> lun move-in-volume -vserver vs1 -path /vol/vol1/A/lun1 -new-path /vol/vol1/B/lun1
s1       /vol/vol1/B/lun1                online  mapped   linux        10MB
Moves LUN lun1 from qtree A to qtree B on volume vol1 .
