ONTAP 9.8 commands
system controller slot module insert
Add a module on the controller
The system controller slot module insert command adds a module on the controller.
-node {<nodename>|local} - Node
Selects the PCIe modules that are present in the specified node.
-slot <text> - Slot Number
Selects the PCIe modules present in the specified slot or slot-subslot combination.
The following example adds a module in the local node:
p2i030::> system controller slot module insert -node local -slot 1
Warning: IO_CARRIER_NIANTIC_NIC module in slot 1 of node p2i030 will be powered
          on and initialized.
Do you want to continue? {y|n}:y
The module has been successfully powered on, initialized and placed into service.
p2i030::>
