network port broadcast-domain merge
Merges two layer 2 broadcast domains
Merges a broadcast domain into an existing broadcast domain.
-ipspace <IPspace>- IPspace Name-
The IPspace of the broadcast domain.
-broadcast-domain <Broadcast Domain>- Layer 2 Broadcast Domain-
The merging broadcast domain.
-into-broadcast-domain <Broadcast Domain>- Merge with This Layer 2 Broadcast Domain-
The target broadcast domain for the merge operation.
The following example merges broadcast domain "bd-mgmt" in IPspace "Default" to broadcast domain "bd-data".
cluster1::network port broadcast-domain> merge -ipspace Default -broadcast-domain bd-mgmt -into-broadcast-domain bd-data
