The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network port broadcast-domain merge
PDF of this doc site
Creating your file...
Your file is ready
Merges two layer 2 broadcast domains
Merges a broadcast domain into an existing broadcast domain.
-ipspace <IPspace>
- IPspace Name-
The IPspace of the broadcast domain.
-broadcast-domain <Broadcast Domain>
- Layer 2 Broadcast Domain-
The merging broadcast domain.
-into-broadcast-domain <Broadcast Domain>
- Merge with This Layer 2 Broadcast Domain-
The target broadcast domain for the merge operation.
The following example merges broadcast domain "bd-mgmt" in IPspace "Default" to broadcast domain "bd-data".
cluster1::network port broadcast-domain> merge -ipspace Default -broadcast-domain bd-mgmt -into-broadcast-domain bd-data
