statistics preset detail show
Display information about Performance Preset Details
Displays the specific details of each preset, including the objects sampled, the counter sample periods, and the counters sampled.
{ [-fields <fieldname>,…​]
Selects which performance preset detail attributes to display.
| [-instance ] }
Displays all of the performance preset detail attributes.
[-preset <text>] - Preset Name
Selects the performance preset details that match the specified preset name.
[-object <text>] - Performance Object
Selects the performance preset details that match the specified object name.
[-sample-period <sample_period>] - Archive Sample period
Selects the performance preset details that are collected at the specified sample period.
[-counter-set <text>,…​] - Performance Counter Name Set
Selects the performance preset details that match the specified counters in the counter set. Use "|" to separate multiple counters.
[-instance-filters <text>,…​] - Performance Instance Filters
Selects the performance preset details that match the specified instance filters. Use "|" to separate multiple instance filters. This field is reserved for future use.
cluster1::*> statistics preset detail show
                         Sample Counter        Instance
Preset Name Object       Period Set            Filters
asup-event  aggregate    1w     instance_name, -
                                node_name,
                                process_name,
                                parent_host,
                                total_
                                transfers,
                                user_reads,
                                user_writes,
                                cp_reads,
                                user_read_
                                blocks,
                                user_write_
                                blocks,
                                cp_read_
                                blocks,
                                wv_fsid,
                                wv_vol_type,
                                wv_fsinfo_fs_
                                version,
                                wv_volinfo_fs_
                                options,
