statistics preset detail show
Display information about Performance Preset Details
Displays the specific details of each preset, including the objects sampled, the counter sample periods, and the counters sampled.
[-fields <fieldname>,…] -
Selects which performance preset detail attributes to display.
[-instance ]} -
Displays all of the performance preset detail attributes.
[-preset <text>]- Preset Name (privilege: advanced)-
Selects the performance preset details that match the specified preset name.
[-object <text>]- Performance Object (privilege: advanced)-
Selects the performance preset details that match the specified object name.
[-sample-period <sample_period>]- Archive Sample period (privilege: advanced)-
Selects the performance preset details that are collected at the specified sample period.
[-counter-set <text>,…]- Performance Counter Name Set (privilege: advanced)-
Selects the performance preset details that match the specified counters in the counter set. Use "|" to separate multiple counters.
[-instance-filters <text>,…]- Performance Instance Filters (privilege: advanced)-
Selects the performance preset details that match the specified instance filters. Use "|" to separate multiple instance filters. This field is reserved for future use.
cluster1::*> statistics preset detail show
Sample Counter Instance
Preset Name Object Period Set Filters
asup-event aggregate 1w instance_name, -
node_name,
process_name,
parent_host,
total_
transfers,
user_reads,
user_writes,
cp_reads,
user_read_
blocks,
user_write_
blocks,
cp_read_
blocks,
wv_fsid,
wv_vol_type,
wv_fsinfo_fs_
version,
wv_volinfo_fs_
options,
