storage tape reset
Reset a tape drive
This command resets a specified tape drive.
-node {<nodename>|local}
- Node-
Use this parameter to specify the node to which the tape drive is attached.
-device-id <text>
- Tape Drive Device ID-
Use this parameter to specify the device ID of the tape drive is to be reset.
The following example resets the tape drive with device ID sw4:2.126L3 attached to the node, cluster1-01.
cluster1::> storage tape reset -node cluster1-01 -device-id sw4:2.126L3
