storage tape trace
Enable/disable tape trace operations
This command enables or disables diagnostic tape trace operations for all tape drives attached to the node you have specified.
-node {<nodename>|local} - Node
Use this parameter to specify the node on which the tape trace feature is enabled or disbled.
[-is-trace-enabled {true|false}] - Tape Trace Enabled or Disabled
Use this parameter to enable or disable the tape trace feature. By default, the tape trace feature is enabled.
The following example enables tape trace operation on the node, cluster1-01.
cluster1::> storage tape trace -node cluster1-01 -is-trace-enabled true
