ONTAP commands
system cluster-switch configure-health-monitor
Cluster-switch health-monitor no-ontap-dependency(NOD) configuration setup
The system cluster-switch configure-health-monitor command downloads non-legacy cluster-switch's no-ontap-dependency(NOD) configuration file in the zip format, where it contains the XML file and a signed version. After download, ONTAP will do security signing check. If passed, cluster-switch health-monitor restarts to use the new cluster-switch configuration file.
-node {<nodename>|local} - Node (privilege: advanced)
This specifies the node or nodes on which the NOD configuration file is to be updated.
-package-url <text> - Package URL (privilege: advanced)
This parameter specifies the URL that provides the location of the package to be fetched. Standard URL schemes, including HTTP, HTTPS, FTP and FILE, are accepted.
The following example downloads NOD configuration file to node1 from a web server and enables cshmd to process it:
cluster1::*> system cluster-switch configure-health-monitor -node node1 -package-url
http://example.com/nod_config.zip
