vserver iscsi show
Display a Vserver's iSCSI configuration
This command displays the current configuration of the iSCSI service.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <Vserver Name>]- Vserver
Selects the iSCSI services for the Vserver that matches the parameter value.
- [-target-name <text>]- Target Name
Selects the iSCSI services with a target name that matches the parameter value.
- [-target-alias <text>]- Target Alias
Selects the iSCSI services with a target alias that matches the parameter value.
- [-status-admin {down|up}]- Administrative Status
Selects the iSCSI services with a configured status that matches the parameter value.
- [-retain-timeout <integer>]- RFC3720 DefaultTime2Retain Value (in sec) (privilege: advanced)
Selects the iSCSI services with a wait time that matches the parameter value. The wait time is the amount of time before active task reassignment is possible after an unexpected connection termination.
- [-login-timeout <integer>]- Login Phase Duration (in sec) (privilege: advanced)
Selects the iSCSI services with a login phase duration that matches the parameter value.
- [-max-conn-per-session <integer>]- Max Connections per Session (privilege: advanced)
Selects the iSCSI services with a maximum connection per session that matches the parameter value.
- [-max-ios-per-session <integer>]- Max Commands per Session (privilege: advanced)
Selects the iSCSI services with a maximum number of commands per session that matches the parameter value.
- [-tcp-window-size <integer>]- TCP Receive Window Size (in bytes) (privilege: advanced)
Selects the iSCSI services with a TCP receive window size (in bytes) that matches the parameter value.
cluster1::> vserver iscsi show
           Target                           Target                       Status
Vserver    Name                             Alias                        Admin
vs_1       iqn.1992-08.com.example:sn.c7c82a22bf9f11df83e5123478563412:vs.2
                                            vs_1_alias                   up
1 entries were displayed.
cluster1::> vserver iscsi show -instance
Vserver: vs_1
                            Target Name: iqn.1992-08.com.example:sn.c7c82a22bf9f11df83e5123478563412:vs.2
The following is the output of the show command at the advanced privilege level:
Target Alias: vs_1_alias
                  Administrative Status: up
Displays the output of the show command at the admin privilege level.
cluster1::*> vserver iscsi show
                                            vs_1_alias                   up
Displays the output of the show command at the advanced privilege level.
cluster1::*> vserver iscsi show -instance
Vserver: vs_1
RFC3720 DefaultTime2Retain Value (in sec): 20
            Login Phase Duration (in sec): 15
              Max Connections per Session: 4
                      Max I/O per Session: 128
  TCP Window Size all Sessions (in bytes): 131400
Displays the detailed entries for all entries.
 PDFs
PDFs
