security login rest-role modify
Modify an access REST control role
The security login rest-role modify command modifies an access-control role.
-vserver <Vserver Name>- Vserver-
This optionally specifies the Vserver name associated with the role.
-role <text>- Role Name-
This specifies the role that is to be modified.
-api <text>- api path-
This specifies the api to which the role has access.
[-access <Access>]- Access Level-
This optionally specifies a new access level for the role. Possible access level settings are none, readonly, and all. The default setting is
all.
The following command modifies an access-control role with the role name readonly and the api access "/api/storage/volume" to have the access level readonly for Vserver vs.example.com:
cluster1::> security login rest-role modify -role readonly -api /api/storage/volume -access readonly -vserver vs.example.com
