system node virtual-machine hypervisor show
Display hypervisor information about Data ONTAP-v nodes
The system node virtual-machine hypervisor show
command displays information for each hypervisor that is hosting a Data ONTAP virtual machine. The output contains the hypervisor-specific information, such as host name and IP address, as well as network configuration details. The command only scans hypervisors on which Data ONTAP virtual machines are installed. To filter command output, specify any number of optional fields listed below.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
The name of the Data ONTAP node running in a virtual machine for which information is to be displayed. If this optional parameter is not specified, the command displays information about all nodes in the cluster.
[-vm-uuid <UUID>]
- UUID of the Virtual Machine-
The hypervisor-supplied unique ID for this virtual machine. This optional parameter selects information about the hypervisor on which the Data ONTAP virtual machine is running with the specified UUID. Since UUID is unique per host, an alternative and easier way is to use
-node
to filter out the same information. [-vmhost-bios-release-date <text>]
- Release Date for the Hypervisor BIOS-
The release date for the currently running hypervisor BIOS. This optional parameter selects information about the hypervisors that have the specified BIOS release date.
[-vmhost-bios-version <text>]
- Current BIOS Version of the Hypervisor Physical Chassis-
The current BIOS version of the hypervisor physical chassis. This optional parameter selects information about the hypervisors that are running with the specified BIOS version.
[-vmhost-boot-time <text>]
- Time When Hypervisor was Last Booted-
The time when the hypervisor was last booted. This optional parameter selects information about the hypervisors which were last booted at the specified boot time.
[-vmhost-cpu-clock-rate <integer>]
- Speed of the Hypervisor CPU Cores (MHz)-
The speed of the hypervisor CPU cores. This optional parameter selects information about the hypervisors that are running with the specified CPU clock rate.
[-vmhost-cpu-core-count <integer>]
- Number of Physical CPU Cores on the Hypervisor-
The number of physical CPU cores on the hypervisor. Physical CPU cores are the processors contained by a CPU package. This optional parameter selects information about the hypervisors that are running with the specified CPU cores.
[-vmhost-cpu-socket-count <integer>]
- Number of Physical CPU Packages on the Hypervisor-
The number of physical CPU packages on the hypervisor. Physical CPU packages are chips that contain one or more processors. Processors contained by a package are also known as CPU cores. For example, one dual-core package is comprised of one chip that contains two CPU cores. This optional parameter selects information about the hypervisors that are running with the specified CPU sockets.
[-vmhost-cpu-thread-count <integer>]
- Number of Physical CPU Threads on the Hypervisor-
The number of physical CPU threads on the hypervisor. This optional parameter selects information about the hypervisors that are running with the specified CPU threads.
[-vmhost-gateway <text>]
- Default Gateway for the Hypervisor-
The default gateway for the hypervisor. This optional parameter selects information about the hypervisors with the specified gateway address.
[-vmhost-hardware-vendor <text>]
- Hardware Vendor of the Hypervisor-
The name of hypervisor hardware manufacturer. This optional parameter selects information about the hypervisors with the specified hardware vendor.
[-vmhost-hypervisor <text>]
- Complete Product Name, including the Version Information for the Hypervisor-
The complete product name, including the version information for the hypervisor. This optional parameter selects information about the hypervisors that are running with the specified hypervisor version.
[-vmhost-ip-address <text>]
- Primary IP Address Assigned to the Hypervisor-
The primary IP address assigned to the hypervisor. This optional parameter selects information about the hypervisors with the specified IP address.
[-vmhost-memory <integer>]
- Physical Memory Size of the Hypervisor (Bytes)-
The physical memory size of the hypervisor in bytes. This optional parameter selects information about the hypervisors that are running with the specified physical memory.
[-vmhost-model <text>]
- Hypervisor Manufacturer-Supplied Hardware Model Name-
The hypervisor manufacturer-supplied hardware model name. This optional parameter selects information about the hypervisors with the specified hardware model.
[-vmhost-name <text>]
- Hostname of the Hypervisor-
The host name assigned to the hypervisor. This optional parameter selects information about the hypervisor with the specified host name.
[-vmhost-netmask <text>]
- Subnet Mask Address for the Hypervisor-
The subnet mask address for the hypervisor. This optional parameter selects information about the hypervisors with the specified netmask address.
[-vmhost-processor-id <text>]
- Processor ID of the Hypervisor-
The processor ID of the hypervisor. This optional parameter selects information about the hypervisors with the specified processor ID.
[-vmhost-processor-type <text>]
- CPU Model of the Hypervisor-
The CPU model of the hypervisor. This optional parameter selects information about the hypervisors that are running with the specified processor type.
[-vmhost-software-vendor <text>]
- Name of the Virtual Machine Software Manufacturer-
The name of the virtual machine software manufacturer. This optional parameter selects information about the hypervisors with the specified software vendor.
[-vmhost-uuid <UUID>]
- UUID of the Hypervisor-
A unique ID for the hypervisor. This optional parameter selects information about the hypervisor with the specified UUID.
[-vmhost-error <text>]
- Error in case Hypervisor Info Retrieval Fails-
Displays a list of nodes on which the hypervisor has received the specified error. This parameter is most useful when entered with wildcards.
[-vm-custom-max-capacity <integer>]
- Maximum Storage Capacity of the Virtual Machine (in TB)-
The maximum system capacity (in TB) that can be configured on the VM. This optional parameter selects information about the node’s storage capacity.
The following example shows typical output from the system node virtual-machine hypervisor show
command for the Data ONTAP virtual machines running in the cluster.
cluster1::> system node virtual-machine hypervisor show Virtual Machine Info -------------------- Node: node1 VM UUID: 123abcde-4f5g-6h78-i9j0-k12l3m4567np Hypervisor Info -------------------- Hardware Vendor: VMware, Inc. Model: VMware Virtual Platform Software Vendor: Unknown Hypervisor: VMware ESX 4.1.0 build-12345 Host Name: myesx.example.com Last Boot Time: 2014-01-01T01:23:45.678901-23:45 Host UUID: 00000000-0000-0000-0000-0012a3456789 BIOS Version: S1234.5.6.7.8.901234567890 BIOS Release Date: 2013-01-01T00:00:00Z CPU Packages: 2 CPU Cores: 12 CPU Threads: 24 Processor ID: 0000:0000:0000:0010:0010:0100:1100:0010 Processor Type: Intel(R) Xeon(R) CPU X5670 @ 2.93GHz CPU MHz: 2925 Memory Size: 4227858432 IPv4 Configuration: IP Address: 192.168.0.1 Netmask: 255.255.255.0 Gateway: 192.165.0.1 Virtual Machine Info -------------------- Node: node2 VM UUID: 123abcde-4f5g-6h78-i9j0-k98l7m6543yz Hypervisor Info -------------------- Hardware Vendor: VMware, Inc. Model: VMware Virtual Platform Software Vendor: Unknown Error: ServerFaultCode: InvalidLoginFault type='InvalidLogin' 2 entries were displayed.
