volume encryption secure-purge show
Show status of secure-purge operation on a volume
The volume encryption secure-purge show command displays information about volume encryption securepurge operation in the cluster.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver (privilege: advanced)
This parameter specifies the Vserver on which the volume is located.
- [-volume <volume name>]- Volume (privilege: advanced)
This parameter specifies the name of the volume being secure purged.
- [-status {invalid|initializing|snapshots-deleting|snapshots-deleted|zombies-draining|zombies-drained|batched-free-log-draining|batched-free-log-drained|finishing-trash-purge|finished-trash-purge|reencrypting|aborting|aborted|success|failure}]- Status (privilege: advanced)
This parameter displays the status of the secure purge operation.
The following example shows a sample output for this command:
cluster1::> volume encryption secure-purge show Vserver Volume Secure Purge Phase ----------- ------------- ---------------------- vs1 vol1 reencrypting
 PDFs
PDFs
