storage aggregate plex show
Show plex details
The storage aggregate plex show command displays information for the specified plex. By default, the command displays the following information about all plexes:
Aggregate Name
Plex Name
Is Online
Is Resyncing
Resyncing Percentage
Plex Status
To display detailed information about a single plex, use the -aggregate and -plex parameter.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-aggregate <aggregate name>]- Aggregate
Name of an existing aggregate which contains the plex specified with the -plexparameter.
- [-plex <text>]- Plex Name
Name of a plex which belongs to the aggregate specified with the -aggregateparameter.
- [-status <text>]- Status
Displays plex status. Possible values are: -
normal
failed
empty
invalid
uninitialized
failed assimilation
limbo
active
inactive
resyncing
 These values may appear by themselves or in combination separated by commas, for example, " normal,active".
- [-is-online {true|false}]- Is Online
Selects the plexes that match this parameter value.
- [-in-progress {true|false}]- Resync is in Progress
- [-resyncing-percent <percent>]- Resyncing Percentage
- [-resync-level <integer>]- Resync Level
- [-pool <integer>]- Pool
The following example displays information about all the plexes for all the aggregates:
cluster1::> storage aggregate plex show
                    Is      Is         Resyncing
Aggregate Plex      Online  Resyncing    Percent Status
aggr0     plex0     true    false              - normal,active
aggr1     plex0     true    false              - normal,active
aggr1     plex1     true    false              - normal,active
aggr2     plex0     true    false              - normal,active
aggr2     plex2     true    false              - normal,active
5 entries were displayed.
The following example displays information about plex1 of aggregate aggr1:
cluster1::> storage aggregate plex show -aggregate aggr1 -plex plex1
Aggregate: aggr1
            Plex Name: plex1
               Status: normal,active
            Is Online: true
Resync is in Progress: false
 Resyncing Percentage: -
         Resync Level: -
                 Pool: 1
 PDFs
PDFs
