ONTAP commands
security saml-sp status show
Display SAML service provider configuration status
The security saml-sp status show command displays the SAML Service Provider (SP) status for all nodes in the cluster.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node (privilege: advanced)
This identifies the node in the cluster.
[-status {not-configured|config-in-progress|config-failed|config-success}] - Update Status (privilege: advanced)
This identifies the SAML SP status on the specified node.
[-error-text <text>] - Error Text (privilege: advanced)
This identifies the error text associated with the latest saml SP update for this node.
[-is-enabled {true|false}] - SAML Service Provider Enabled (privilege: advanced)
When this parameter is set to true it indicates that the SAML SP is enabled on this node. Similarly, when this parameter is set to false , it indicates that the SAML SP is not enabled on this node.
The following example displays the SAML SP status information for all nodes in the cluster.
cluster::security saml-sp status> show
Node                            SAML SP Status         Enabled
cluster-node1                   not-configured         false
cluster-node2                   not-configured         false
2 entries were displayed.
cluster::*>
