storage firmware disk show
Display the list of disk firmware files on the given node
The storage firmware disk show command displays the disk firmware files present on each node.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the files that match the specified node name.
[-filename <text>] - Storage Firmware File
Selects the files that match the specified filename.
The following example displays the disk firmware files on each node:
cluster1::> storage firmware disk show
Node: Node1
Disk Firmware Files
                  X262_SMOOST25SSX.NA06.LOD
                  X262_SMOOST25SSX.NA06.LOD.FVF
                  X267_SMOOST50SSX.NA06.LOD
                  X267_SMOOST50SSX.NA06.LOD.FVF
Node: Node2
Disk Firmware Files
                  8 entries were displayed.
