storage firmware disk show
Display the list of disk firmware files on the given node
The storage firmware disk show command displays the disk firmware files present on each node.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the files that match the specified node name.
[-filename <text>]- Storage Firmware File-
Selects the files that match the specified filename.
The following example displays the disk firmware files on each node:
cluster1::> storage firmware disk show
Node: Node1
Disk Firmware Files
X262_SMOOST25SSX.NA06.LOD
X262_SMOOST25SSX.NA06.LOD.FVF
X267_SMOOST50SSX.NA06.LOD
X267_SMOOST50SSX.NA06.LOD.FVF
Node: Node2
Disk Firmware Files
8 entries were displayed.
