vserver cifs domain name-mapping-search show
Display the list of trusted domains for name-mapping searches
The vserver cifs domain name-mapping-search show command displays information about trusted domains of the home domain by Vserver.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
This parameter specifies the name of the Vserver for which you want to display information about the trusted domains.
[-trusted-domains <domain name>,…]- Trusted domains-
This parameter specifies a comma-delimited list of fully qualified domain names of trusted domains for which you want to display information.
The following example displays information about all preferred trusted domains:
cluster1::> vserver cifs domain name-mapping-search show Vserver Trusted Domains -------------- ---------------------------------- vserver_1 CIFS1.EXAMPLE.COM
