snaplock compliance-clock show
Displays the node ComplianceClock
The ` snaplock compliance-clock show ` command will display System ComplianeClock of the nodes in the cluster. It will display the following information:
Node name
ComplianceClock Time
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If this parameter is specified, the command will display ComplianceClock for that particular node only.
[-time <text>]
- ComplianceClock Time of the Node-
If this parameter is specified, the command will display nodes having the same
-time
value.
cluster1::> snaplock compliance-clock show Node ComplianceClock Time ------------------- ----------------------------------- node1 Mon Jan 12 11:34:15 IST 2015 +05:30 node2 Mon Jan 12 11:34:10 IST 2015 +05:30 2 entries were displayed.
cluster1::> snaplock compliance-clock show -node node1 Node ComplianceClock Time ------------------- ----------------------------------- node1 Mon Jan 12 11:34:45 IST 2015 +05:30
