vserver show-aggregates
Show details of aggregates in a Vserver
The vserver show-aggregates command displays the details of all the aggregates that are associated with Vservers. The aggregate details displayed are the aggregate name, state, available size, the type of aggregate and the SnapLock type.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Vserver-
If this optional parameter is specified, the command displays the details of aggregates that are associated with the specified Vserver.
[-aggregate <aggregate name>]- Aggregate-
If this optional parameter is specified, the command displays all of the Vservers configured with the specified aggregate.
The following example displays the aggregates configured for Vserver vs.
cluster1::> vserver show-aggregates -vserver vs
Available
Vserver Aggregate State Size Type SnapLock-Type
vs aggr1 online 795.2MB hdd non-snaplock
vs aggr2 online 795.2MB hdd non-snaplock
2 entries were displayed.
