network port broadcast-domain modify
Modify a layer 2 broadcast domain
Modify a broadcast domain.
-ipspace <IPspace>- IPspace Name-
The IPspace to which the broadcast domain belongs.
-broadcast-domain <Broadcast Domain>- Layer 2 Broadcast Domain-
The name of the broadcast domain.
[-mtu <integer>]- Configured MTU-
MTU of the broadcast domain.
The following example modifies the mtu attribute of broadcast domain "mgmt" in IPspace "Default" to 1500
cluster1::network port broadcast-domain*> modify -ipspace Default -broadcast-domain mgmt -mtu 1500
