vserver vscan on-demand-task report show
Display On-Demand reports
The vserver vscan on-demand-task report show command displays information about the On-Demand reports belonging to the Vserver. A new report record is generated at the end of an On-Demand task run. If you do not specify any parameters, the command displays the following information about all On-Demand tasks:
Vserver name
Task name
Report file path
Number of clean files
Number of infected files
You can specify the -fields parameter to specify which fields of information to display about On-Demand report. In addition to the fields above, you can display the following fields:
Job ID
Job duration
Number of attempted scans
Number of files skipped from scanning
Number of already scanned files
Number of successful scans
Number of failed scans
Number of timed-out scans
Job start time
Job end time
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver
If you specify this parameter, the command displays information only about the On-Demand reports for the specified Vserver.
- [-task-name <text>]- Task Name
If you specify this parameter, the command displays information only about the On-Demand reports for the specified task.
- [-report-file <text>]- Report File Path
If you specify this parameter, the command displays information only about the On-Demand reports that have the specified report file-path.
- [-job-id <integer>]- Job ID
If you specify this parameter, the command displays information only about the On-Demand reports that have the specified job ID.
- [-job-duration <[<integer>h][<integer>m][<integer>s]>]- Job Duration
If you specify this parameter, the command displays information only about the On-Demand reports that have the specified value.
- [-attempted-scans <integer>]- Number of Attempted Scans
- [-skipped-scans <integer>]- Number of Files Skipped from Scanning
- [-already-scanned-files <integer>]- Number of Already Scanned Files
- [-successful-scans <integer>]- Number of Successful Scans
- [-failed-scans <integer>]- Number of Failed Scans
- [-timedout-scans <integer>]- Number of Timedout Scans
- [-files-cleaned <integer>]- Number of Clean Files
- [-files-infected <integer>]- Number of Infected Files
- [-internal-error <integer>]- Number of Internal Error (privilege: advanced)
- [-scan-retries <integer>]- Number of Scan Retries (privilege: advanced)
- [-job-start-time <MM/DD/YYYY HH:MM:SS>]- Job Start Time
- [-job-end-time <MM/DD/YYYY HH:MM:SS>]- Job End Time
The following example displays information about all On-Demand reports:
cluster1::> vscan on-demand-task report show
                                                               Files     Files
Vserver     Task Name   Report File Path                     Cleaned  Infected
vs1         t1          /rep/avod_146_20150902_161439.log       6240         5
vs1         t1          /rep/avod_149_20150903_160313.log        115         0
2 entries were displayed.
The following example displays detailed information about an On-Demand task:
cluster1::> vscan on-demand-task report show -vserver vs1 -task-name t1
            -report-file /rep/avod_146_20150902_161439.log
Vserver: vs1
                            Task Name: t1
                     Report File Path: /rep/avod_146_20150902_161439.log
                               Job ID: 146
                         Job Duration: 76s
            Number of Attempted Scans: 6245
Number of Files Skipped from Scanning: 1286
      Number of Already Scanned Files: 987
           Number of Successful Scans: 6245
               Number of Failed Scans: 0
             Number of Timedout Scans: 0
                Number of Clean Files: 6240
             Number of Infected Files: 5
                       Job Start Time: 9/2/2015 16:14:39
                         Job End Time: 9/2/2015 16:15:55
 PDFs
PDFs
