statistics disk show
Disk throughput and latency metrics
This command continuously displays performance data for disks at a regular interval. The command output displays data in the following columns:
Disk - disk name.
Node - node name.
Busy (%) - percentage of time there was at least one outstanding request to the disk.
Total Ops - total operations per second.
Read Ops - read operations per second.
Write Ops - write operations per second.
- [-disk <text>]- Disk (privilege: advanced)
Selects the disk for which you want to display performance data.
- [-node {<nodename>|local}]- Node (privilege: advanced)
Selects the node for which you want to display performance data.
- [-sort-key <text>]- Column to Sort By (privilege: advanced)
If this parameter is specified, the command displays statistics sorted by the specified column.
- -interval <integer>- Interval (privilege: advanced)
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
- -iterations <integer>- Iterations (privilege: advanced)
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
- -max <integer>- Maximum Number of Instances (privilege: advanced)
Specifies the maximum number of disks to display. The default setting is 25.
The following example displays disk statistics:
cluster1::> statistics disk show
cluster1 : 12/31/1969 16:00:04
                   Busy *Total Read Write
 Disk         Node  (%)    Ops  Ops   Ops
 VMw-1.31    node2    0      2    2     0
 VMw-1.30    node2    0      3    0     3
 VMw-1.3     node1    0      0    0     0
 VMw-1.29    node2    0      1    0     1
 PDFs
PDFs
