ONTAP commands
system configuration backup delete
Delete a configuration backup
The system configuration backup delete command deletes a saved configuration backup.
Use the system configuration backup show command to display saved configuration backups.
-node {<nodename>|local} - Node (privilege: advanced)
Use this parameter to specify the name of the source node where the configuration backup currently exists.
-backup <text> - Backup Name (privilege: advanced)
Use this parameter to specify the name of the configuration backup file to delete.
The following example shows how to delete the configuration backup file node1.special.7z from the node node1 .
cluster1::*> system configuration backup delete -node node1 -backup node1.special.7z
