volume snaplock show
Display SnapLock attributes of a SnapLock volume
The ` volume snaplock show ` command displays following information :
Vserver name
Volume name
SnapLock Type of the volume
Minimum retention period applicable of the volume
Default retention period applicable of the volume
Maximum retention period applicable of the volume
Autocommit period of the volume
Volume Append Mode attribute of the volume
Privileged Delete attribute of the volume
Litigation count on the volume
Volume expiry time of the volume
Volume ComplianceClock
SnapLock audit log volume
This command is applicable only for SnapLock volumes.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If this parameter is specified, the command displays information for all the SnapLock volumes that match the specified
-vserver
value. [-volume <volume name>]
- Volume-
If this parameter is specified, the command displays information for the specified
-volume
value. [-type {non-snaplock|compliance|enterprise}]
- SnapLock Type-
If this parameter is specified, the command displays all the volumes that match the specified
-type
value. [-minimum-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]
- Minimum Retention Period-
value. [-default-retention-period {{<integer> seconds|minutes|hours|days|months|years} | min | max | infinite}]
- Default Retention Period-
value. [-maximum-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]
- Maximum Retention Period-
value. [-autocommit-period {{<integer> minutes|hours|days|months|years} | none}]
- Autocommit Period-
-autocommit-period
value. [-is-volume-append-mode-enabled {true|false}]
- Is Volume Append Mode Enabled-
value. [-privileged-delete {disabled|enabled|permanently-disabled}]
- Privileged Delete-
-privileged-delete
value. [-expiry-time <text>]
- Expiry Time-
-expiry-time
value. [-compliance-clock-time <text>]
- ComplianceClock Time-
value. [-litigation-count <integer>]
- Litigation Count-
-litigation-count
value. [-is-audit-log-volume {true|false}]
- Is SnapLock Audit Log Volume-
value.
The following command shows summary of SnapLock volumes on a vserver:
cluster1::> volume snaplock show Vserver Volume SnapLock Type ComplianceClock Time ------------- --------------- ------------- ----------------------------------- vs1 vol_slc compliance Mon Jan 19 14:12:34 IST 2015 +05:30 vs1 vol_sle enterprise Mon Jan 19 14:12:34 IST 2015 +05:30 2 entries were displayed. cluster1::>
The following commands lists the complete SnapLock attributes of two given SnapLock volumes:
cluster1::> volume snaplock show -vserver vs1 -volume vol_slc Vserver Name: vs1 Volume Name: vol_slc SnapLock Type: compliance Minimum Retention Period: 1 years Default Retention Period: max Maximum Retention Period: 30 years Autocommit Period: 12 hours Is Volume Append Mode Enabled: false Privileged Delete: permanently-disabled Expiry Time: Thu May 11 14:37:21 GMT 2017 ComplianceClock Time: Wed May 11 20:08:41 IST 2016 +05:30 Litigation Count: 0 Is SnapLock Audit Log Volume: false cluster1::> cluster1::> volume snaplock show -vserver vs1 -volume vol_sle Vserver Name: vs1 Volume Name: vol_sle SnapLock Type: enterprise Minimum Retention Period: 6 months Default Retention Period: min Maximum Retention Period: infinite Autocommit Period: none Is Volume Append Mode Enabled: false Privileged Delete: enabled Expiry Time: infinite ComplianceClock Time: Wed May 11 20:08:44 IST 2016 +05:30 Litigation Count: 0 Is SnapLock Audit Log Volume: false
