vserver nfs kerberos interface modify
Modify the Kerberos configuration of an NFS server
The vserver nfs kerberos interface modify command modifies a Kerberos configuration for NFS. An NFS Kerberos configuration is associated with both a Vserver and a logical interface.
-vserver <vserver name>- Vserver-
This parameter specifies the Vserver associated with the NFS Kerberos configuration you want to modify.
-lif <text>- Logical Interface-
This parameter specifies the name of the logical interface associated with the NFS Kerberos configuration you want to modify.
[-kerberos {enabled|disabled}]- Kerberos Enabled-
This optional parameter specifies whether to enable or disable Kerberos for NFS on the specified Vserver and logical interface. If you specify a value of
enable, you must also specify the -spn parameter. The command prompts you for a user name and password for a Kerberos principal in the same realm as the principal specified by the-spnparameter; this principal must have permission to create or modify the principal specified by the-spnparameter. [-spn <text>]- Service Principal Name-
This optional parameter specifies the service principal name (SPN) of the Kerberos configuration you want to modify. If you specify a value of
enablefor the-kerberosparameter, you must also specify this parameter. This value must be in the form nfs/host_name@REALM, wherehost_nameis the fully qualified host name of the Kerberos server, nfs is the service, andREALMis the name of the Kerberos realm (for instance, EXAMPLE.COM). Specify Kerberos realm names in uppercase. [-admin-username <text>]- Account Creation Username-
This optional parameter specifies the administrator user name.
[-keytab-uri {(ftp|http)://(hostname|IPv4 Address|'['IPv6 Address']')…}]- Load Keytab from URI-
This optional parameter specifies loading a keytab file from the specified URI.
[-ou <text>]- Organizational Unit-
This optional parameter specifies the organizational unit (OU) under which the Microsoft Active Directory server account will be created when you enable Kerberos using a realm for Microsoft KDC. If this parameter is not specified, the default OU is "CN=Computers".
[-machine-account <text>]- Machine Account Name-
This optional parameter specifies the machine account to create in Active Directory
The following example enables an NFS Kerberos configuration on a Vserver named vs0 and a logical interface named datalif1. The SPN is nfs/sec.example.com@AUTH.SEC.EXAMPLE.COM and the keytab file is loaded from ftp://ftp.example.com/keytab.
vs1::> vserver nfs kerberos interface modify -vserver vs0 -lif datalif1 -kerberos enabled -spn nfs/sec.example.com@AUTH.SEC.EXAMPLE.COM -keytab-uri ftp://ftp.example.com/keytab
