ONTAP 9.7 commands
storage bridge run-cli
Execute an ATTO CLI command on a bridge
The storage bridge run-cli command enables you to execute an ATTO bridge command.
-name <text> - Bridge Name
This parameter specifies the name of the bridge that the command is to be executed on.
-command <text> - ATTO CLI command to execute
This parameter specifies the command to be executed on the named bridge.
The following example executes a command on a bridge
sti8040mcc-201_siteA::> storage bridge run-cli -name ATTO_FibreBridge7500N_1 -command "Help"
