system node image show-update-progress
Show progress information for a currently running update
The system node image show-update-progress
command displays the progress of a software-image update initiated by using the system node image update command. The command displays progress until the update completes; you can also interrupt it by pressing Ctrl-C.
-node {<nodename>|local}
- Node-
This optionally specifies the name of a node whose image-update progress is to be displayed.
[-follow <true>]
- Follow the Progress in the Foreground-
Do use not use background processing for this command. If you do not use this parameter, the value is
true
The following example displays image-update progress:
node::> system node image show-update-progress ERROR: command failed: There is no update/install in progress
