vserver cifs users-and-groups local-group show-members
Display local groups' members
The vserver cifs users-and-groups local-group show-members command displays members of a local group. The members can be local or Active Directory users or groups.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver-
If this parameter is specified, the command displays group members of local groups that match the specified Vserver name.
[-group-name <CIFS name>]- Group Name-
If this parameter is specified, the command displays group members of local groups that match the specified group name.
[-member <CIFS name>,…]- Member Name-
If this parameter is specified, the command displays group members that match the specified member name. The name can be that of a local user, Active Directory user, or Active Directory group.
The following example displays members of local groups associated with Vserver "vs1".
cluster1::> vserver cifs users-and-groups local-group show-members -vserver vs1
Vserver Group Name Members
vs1 BUILTIN\Administrators CIFS_SERVER\Administrator
AD_DOMAIN\Domain Admins
AD_DOMAIN\dom_grp1
BUILTIN\Users AD_DOMAIN\Domain Users
AD_DOMAIN\dom_usr1
CIFS_SERVER\g1 CIFS_SERVER\u1
6 entries were displayed.
