system controller bootmedia show-serial-number
Display the Boot Media Device serial number
The system controller bootmedia show-serial-number command displays the Boot Media Device serial number. These commands are available for 80xx, 25xx and later systems. Earlier models are not supported. By default, the command displays the following information about the bootmedia:
Node name
Display name
Serial Number
Size
Bootmedia state
Status
To display more details, use the -instance parameter.
[-fields <fieldname>,…] -
Selects the fields that you specify.
[-instance ]} -
Displays detailed information for all the bootmedia devices.
[-node {<nodename>|local}]- Node-
Selects the bootmedia device that is present on the specified node.
[-serial-num <text>]- Serial Number-
Selects the bootmedia devices with the specified serial number.
[-vendor-id <Hex Integer>]- Vendor ID-
Selects the bootmedia devices with the specified vendor ID.
[-device-id <Hex Integer>]- Device ID-
Selects the bootmedia devices with the specified device ID.
[-display-name <text>]- Display Name-
Selects the bootmedia devices with the specified display name.
[-unique-name <text>]- Unique Name-
Selects the bootmedia device with the specified unique name.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example}]- Health Monitor Name-
Selects the bootmedia devices with the specified health monitor.
[-usbmon-status {present|not-present}]- Bootmedia Health Monitor-
Selects the bootmedia devices with the specified USBMON status.
[-device-state {good|warn|bad}]- Bootmedia State-
Selects the bootmedia devices with the specified device state.
[-size <integer>]- Max Memory Size (MB)-
Selects the bootmedia devices with the specified memory size.
[-health {ok|ok-with-suppressed|degraded|unreachable|unknown}]- Status-
Selects the bootmedia devices with the specified health monitor status.
The following example displays the information of the bootmedia devices present in all the nodes in a cluster:
cluster1::> system controller bootmedia show-serial-number
Node Display Name Serial Number (MB) State Status
or-12-01
BootMedia/SAMSUNG S2J4NXAGA08186 122104 good ok
MZVLV128HCGR-00000
BootMedia-2/SAMSUNG S2J4NXAGA08198 122104 good ok
MZVLV128HCGR-00000
2 entries were displayed.
The following example displays the detailed information about the bootmedia present in a node:
cluster1::> system controller bootmedia show-serial-number -instance -node node1
Node: node1
Vendor ID: 8086
Device ID: 8d02
Display Name: TOSHIBA THNSNJ060GMCU
Unique Name: /dev/ad4s1 (TOSHIBA THNSNJ060GMCU)
Health Monitor Name: controller
Bootmedia Health Monitor: present
Bootmedia State: good
Max memory size(in MB): 16367
Status: ok
Serial number: Y4IS104FTNEW
