ONTAP commands
system ha interconnect statistics performance show
Display the high-availability interconnect device performance statistics
The system ha interconnect statistics performance show command displays the high-availability interconnect device performance statistics.
{ [-fields <fieldname>,…​]
If you specify the -fields <fieldname>,…​ parameter, the command displays only the fields that you specify.
| [-instance ] }
Use this parameter to display all the fields from all nodes in cluster.
[-node {<nodename>|local}] - Node (privilege: advanced)
Use this parameter to display all the fields from the specified node in the cluster.
[-elapsed <integer>] - Elapsed Time (secs) (privilege: advanced)
Selects the nodes that match this parameter value. Displays the total elapsed time between statistics collection start time to end time. During the initialization stage, statistics collection starts when the partner node is up and ready. After the initialization stage, the statistics collection start time is reset after every execution of this command. This means that after the initialization stage, elapsed time represents the time between current command execution and previous command execution.
[-qmax-wait <integer>] - Maximum Queue Wait Count (privilege: advanced)
Selects the nodes that match this wait value. The queue maximum wait value is the total number of times the interconnect device waited to post requests on the send queue.
[-qmax-wait-time <integer>] - Average Queue Wait Time (usecs) (privilege: advanced)
Selects the nodes that match this average wait time value. The queue maximum wait time is the average amount of time the interconnect device waited to post requests on the send queue.
[-qmax-timeout <integer>] - Maximum Queue Timeouts (privilege: advanced)
Selects the nodes that match this parameter value. The queue maximum timeout value is the total number of times the interconnect device timed out waiting to post requests on the send queue.
[-preempt-timeout <integer>] - Preempt Timeouts (privilege: advanced)
Selects the nodes that match this parameter value. The timeout value is the total number of times polling on the given transfer ID is preempted.
[-nonpreempt-timeout <integer>] - Non-Preempt Timeouts (privilege: advanced)
Selects the nodes that match this parameter value. The timeout value is the total number of times polling on the given transfer ID stopped due to interconnect device read/write timeout.
[-notify-timeout <integer>] - Notify Timeouts (privilege: advanced)
Selects the nodes that match this parameter value. The timeout value is the total number of times data transfer on the HA interconnect timed out.
[-avg-rnv-msgs-time <integer>] - Remote NV Messages Average Time (usecs) (privilege: advanced)
Selects the nodes that match this parameter value. The value is the average time between remote NV messages.
[-rnv-transfers <integer>] - Total Remote NV Transfers (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of remote NV transfers attempted.
[-avg-rnv-transfer-size <integer>] - Remote NV Average Transfer Size (privilege: advanced)
Selects the nodes that match this parameter value. The value is the average remote NV message transfer size.
[-avg-rnv-transfer-time <integer>] - Remote NV Transfers Average Time (usecs) (privilege: advanced)
Selects the nodes that match this parameter value. The value is the average transfer time taken by remote NV messages.
[-ic-waits <integer>] - Total Count of IC waits for Given ID (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of times the interconnect device waits until the transfer of a given ID is successful.
[-ic-waitdone-time <integer>] - Average IC Waitdone Time (usecs) (privilege: advanced)
Selects the nodes that match this parameter value. The value is the average time the interconnect device spent waiting for the IDs to be transferred successfully.
[-ic-isdone <integer>] - Total IC isdone Checks (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of times the interconnect client checked for the completion of a given transfer ID.
[-ic-isdone-pass <integer>] - Total IC isdone Checks Success (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of times the check for the completion of a given transfer ID is successful.
[-ic-isdone-fail <integer>] - Total IC isdone Checks Failed (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of times the check for the completion of a given transfer ID is not successful.
[-ic-small-writes <integer>] - IC Small Writes (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of <4K size writes performed by the interconnect device.
[-ic-4k-writes <integer>] - IC 4K Writes (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of 4K size writes performed by the interconnect device.
[-ic-8k-writes <integer>] - IC 8K Writes (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of 8K size writes performed by the interconnect device.
[-ic-16k-writes <integer>] - IC 16K+ Writes (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of 16K or more size writes performed by the interconnect device.
[-ic-xorder-writes <integer>] - IC XORDER Writes (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of out-of-order writes performed by the interconnect device.
[-ic-xorder-reads <integer>] - IC XORDER Reads (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of out-of-order reads performed by the interconnect device.
[-rdma-read <integer>] - RDMA Reads Count (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of RDMA reads performed by the interconnect device.
[-rdma-read-waitdone-time <integer>] - Average IC Waitdone RDMA-READ Time (usecs) (privilege: advanced)
Selects the nodes that match this parameter value. The value is the average time the interconnect device spent polling for transfer IDs on the RDMA-read channel.
[-avg-mbytes-second <text>] - Average MegaBytes Transferred per second (privilege: advanced)
Selects the nodes that match this parameter value. The value is the average megabytes (MB) transferred per second.
[-avg-bytes-transfer <integer>] - Average Bytes per Transfer (privilege: advanced)
Selects the nodes that match this parameter value. The value is the average amount of bytes sent per transfer.
[-total-transfers <integer>] - Total Transfers (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of transfers made through the interconnect device.
[-avg-nvlog-sync-time <integer>] - Average Time for NVLOG Sync (msecs) (privilege: advanced)
Selects the nodes that match this parameter value. The value is the average time taken to sync NVLOG between HA partner nodes.
[-max-nvlog-sync-time <integer>] - Maximum Time for NVLOG Sync (msecs) (privilege: advanced)
Selects the nodes that match this parameter value. The value is the maximum time taken to sync NVLOG between HA partner nodes.
[-max-sgl-length <integer>] - Maximum Scatter-Gather Elements in a List (privilege: advanced)
Selects the nodes that match this parameter value. The value is the maxmimum length of the scatter-gather list supported by the interconnect device.
[-ic-recq-waits <integer>] - Total Receive Queue Waits to Post Buffer (privilege: advanced)
Selects the nodes that match this parameter value. The value is the total number of times the interconnect device waited to post an empty buffer into the receive queue.
[-avg-recq-wait-time <integer>] - Average Time Receive Queue Waited (usecs) (privilege: advanced)
Selects the nodes that match this parameter value. The value is the average amount of time the interconnect device waited to post an empty buffer into the receive queue.
The following example displays the HA interconnect device performance statistics for FAS8000 series nodes in the cluster:
cluster1::*> system ha interconnect statistics performance show
                                       Node: ic-f8040-01
                        Elapsed Time (secs): 6
                   Maximum Queue Wait Count: 33
            Average Queue Wait Time (usecs): 30
    Remote NV Messages Average Time (usecs): 1437
                  Total Remote NV Transfers: 9297
            Remote NV Average Transfer Size: 348
   Remote NV Transfers Average Time (usecs): 680
                Total IC waits for Given ID: 159
           Average IC Waitdone Time (usecs): 5
                     Total IC isdone Checks: 608
             Total IC isdone Checks Success: 608
              Total IC isdone Checks Failed: 0
                            IC Small Writes: 10129
                               IC 4K Writes: 10
                               IC 8K Writes: 54
                             IC 16K+ Writes: 92
                           IC XORDER Writes: 4855
                            IC XORDER Reads: 0
                            RDMA Read Count: 172
 Average IC Waitdone RDMA-READ Time (usecs): 0
                               Average MB/s: 0.98114
                 Average Bytes per Transfer: 180
                            Total Transfers: 20720
        Average Time for NVLOG Sync (msecs): 1409
        Maximum Time for NVLOG Sync (msecs): 1409
  Maximum Scatter-Gather Elements in a List: 32
   Total Receive Queue Waits to Post Buffer: 0
Node: ic-f8040-02
                        Elapsed Time (secs): 12
                   Maximum Queue Wait Count: 29
            Average Queue Wait Time (usecs): 68
    Remote NV Messages Average Time (usecs): 1386
                  Total Remote NV Transfers: 19190
            Remote NV Average Transfer Size: 375
   Remote NV Transfers Average Time (usecs): 670
                Total IC waits for Given ID: 304
                     Total IC isdone Checks: 1409
             Total IC isdone Checks Success: 1409
                            IC Small Writes: 20964
                               IC 4K Writes: 5
                               IC 8K Writes: 99
                             IC 16K+ Writes: 229
                           IC XORDER Writes: 10261
                            IC XORDER Reads: 0
                            RDMA Read Count: 337
                               Average MB/s: 0.57080
                 Average Bytes per Transfer: 187
                            Total Transfers: 42883
        Average Time for NVLOG Sync (msecs): 1009
        Maximum Time for NVLOG Sync (msecs): 1009
2 entries were displayed
The following example displays the HA interconnect device performance statistics for FAS2500 series nodes in the cluster:
                                       Node: ic-f2554-03
                        Elapsed Time (secs): 253
                   Maximum Queue Wait Count: 11
            Average Queue Wait Time (usecs): 6837
                     Maximum Queue Timeouts: 0
                           Preempt Timeouts: 0
                       Non-Preempt Timeouts: 0
                            Notify Timeouts: 0
    Remote NV Messages Average Time (usecs): 3343
                  Total Remote NV Transfers: 59643
            Remote NV Average Transfer Size: 8715
   Remote NV Transfers Average Time (usecs): 4258
                Total IC waits for Given ID: 180
           Average IC Waitdone Time (usecs): 3187
                     Total IC isdone Checks: 499981
             Total IC isdone Checks Success: 59922
              Total IC isdone Checks Failed: 440059
                            IC Small Writes: 98722
                               IC 4K Writes: 5747
                               IC 8K Writes: 7719
                             IC 16K+ Writes: 25793
                           IC XORDER Writes: 66735
                            IC XORDER Reads: 0
                            RDMA Read Count: 574
 Average IC Waitdone RDMA-READ Time (usecs): 229
                               Average MB/s: 2.1207
                 Average Bytes per Transfer: 4680
                            Total Transfers: 138302
        Average Time for NVLOG Sync (msecs): 1236
        Maximum Time for NVLOG Sync (msecs): 1236
  Maximum Scatter-Gather Elements in a List: 27
Node: ic-f2554-04
                        Elapsed Time (secs): 257
                   Maximum Queue Wait Count: 7
            Average Queue Wait Time (usecs): 10172
                           Preempt Timeouts: 0
                            Notify Timeouts: 0
    Remote NV Messages Average Time (usecs): 4237
                  Total Remote NV Transfers: 47134
            Remote NV Average Transfer Size: 9559
   Remote NV Transfers Average Time (usecs): 5463
                Total IC waits for Given ID: 178
           Average IC Waitdone Time (usecs): 1890
                     Total IC isdone Checks: 393191
             Total IC isdone Checks Success: 47382
              Total IC isdone Checks Failed: 345809
                            IC Small Writes: 78369
                               IC 4K Writes: 3815
                               IC 8K Writes: 6005
                             IC 16K+ Writes: 22993
                           IC XORDER Writes: 53529
                            IC XORDER Reads: 0
                            RDMA Read Count: 524
 Average IC Waitdone RDMA-READ Time (usecs): 62
                               Average MB/s: 2.3682
                 Average Bytes per Transfer: 5143
                            Total Transfers: 111501
        Average Time for NVLOG Sync (msecs): 822
        Maximum Time for NVLOG Sync (msecs): 822
2 entries were displayed.
