vserver cifs group-policy restricted-group show-defined
Show the defined restricted-group settings.
The vserver cifs group-policy restricted-group show-defined command displays settings of all the restricted groups defined in Domain Controller for a Vserver.
If you do not specify any parameters, the command displays the following information about all the restricted groups defined in Domain Controller for all the Vservers in the cluster.
  • Group Policy Name: Specifies the name of the group policy.
  • Version: Specifies the version of the group policy.
  • Link: Specifies the level in which the group policy is configured. Possible values are:
  • Local: Group policy is configured in Data ONTAP.
  • Site: Group policy is configured at the site level in the Domain Controller.
  • Domain: Group policy is configured at the domain level in the Domain Controller.
  • OrganizationalUnit: Group policy is configured at the OU level in the Domain Controller.
  • RSOP: Resultant set of policies derived from all the group policies defined at various levels.
  • Group Name: Specifies the name of a restricted group.
  • Members: Specifies users and groups who belong to and who do not belong to the restricted group.
  • MemberOf: Specifies list of groups to which the restricted group is added. A group can be a member of groups other than the groups listed here.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If this parameter is specified, the command displays the restricted-group information that is defeined in Domain Controller for the specified Vserver.
[-index <integer>] - Index
If this parameter is specified, the command displays the specified index for the group policy in the restricted group. The restricted-group information for the group policy at the specified index.
[-group-name <text>] - Group Name
If this parameter is specified, the command displays the restricted-group information for the specified group name.
[-group-policy-name <text>] - Group Policy Name
If this parameter is specified, the command displays the restricted-group information for the specified group policy name.
[-uuid <UUID>] - UUID
If this parameter is specified, the command displays the restricted-group information for the specified UUID of the group policy.
[-version <integer>] - Version
If this parameter is specified, the command displays the restricted-group information for the specified version of the group policy.
[-link {Local|Site|Domain|OrganizationalUnit|RSOP}] - Link Type
If this parameter is specified, the command displays the restricted-group information for the specified link for the group policy.
[-members <gpoUserGroup>,…​] - Members, List of Users/groups
If this parameter is specified, the command displays the restricted-group information for the specified members of users and groups.
[-member-of <gpoUserGroup>,…​] - MemberOf, List of Groups
If this parameter is specified, the command displays the restricted-group information for the specified member of the group.
The following example displays information about all restricted groups that are defined in Domain Controller for a Vserver.
cluster1::> vserver cifs group-policy restricted-group show-defined
Vserver: vs_1
     Group Policy Name: gpo1
               Version: 16
                  Link: OrganizationalUnit
            Group Name: grp1
               Members: usr1
              MemberOf: GPO\g9
Group Policy Name: Resultant Set of Policy
               Version: 0
                  Link: RSOP
            Group Name: grp1
               Members: usr1
              MemberOf: GPO\g9
