network port ifgrp show
Display port interface groups
The network port ifgrp show command displays information about port interface groups. By default, it displays information about all port interface groups on all nodes in the cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Selects the port interface groups that match this parameter value. Use this parameter with the
-ifgrpparameter to select information about a specific port interface group. [-ifgrp <ifgrp name>]- Interface Group Name-
-nodeparameter, to select information about a specific port interface group. [-distr-func {mac|ip|sequential|port}]- Distribution Function-
[-mode {multimode|multimode_lacp|singlemode}]- Create Policy-
[-mac <MAC Address>]- MAC Address-
[-activeports {full|partial|none}]- Port Participation-
Selects the port interface groups that match this parameter value. The value "partial" indicates that some but not all of the port interface group's ports are active. the value "full" indicates that all of the port interface group's ports are active.
[-ports {<netport>|<ifgrp>}]- Network Ports-
[-up-ports {<netport>|<ifgrp>}]- Up Ports-
Selects the port interface groups that match this parameter value. Displays only the ports that are up.
[-down-ports {<netport>|<ifgrp>}]- Down Ports-
Selects the port interface groups that match this parameter value. Displays only the ports that are down.
The following example displays information about all port interface groups.
cluster1::> network port ifgrp show
Port Distribution Active
Node ifgrp Function MAC Address Ports Ports
node0
a0a ip b8:f8:7a:20:00 partial e0c
node1
a1a ip 07:26:60:02:00 full e0d
