vserver fcp ping-initiator show
Ping FCP initiator
This command performs a connectivity check (ping) between FCP initiators and FCP LIFs.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver-
Use this parameter to select the Vservers that contain FCP initiators and FCP LIFs.
-wwpn <text>- Remote WWPN-
Use this parameter to select the remote WWPN (most likely, FCP initiator).
[-lif <text>]- LIF Name-
Use this parameter to limit the test to a subset of the FCP LIFs available for the igroup.
[-check-fabric <true>]- Query Fabric Records (privilege: advanced)-
Use this parameter to query the unzoned name server for the FCP initiator WWPN.
[-node <nodename>]- Node-
Use this parameter to select the nodes that contain the specified FCP LIFs.
[-status {unknown|reachable|not-reachable|not-zoned|cannot-ping-same-wwpn|fcp-service-busy|lif-is-down|zone-info-not-available}]- Ping Status-
Use this parameter to select the result of FCP ping command.
[-ext-status {logged-in|not-logged_in|not-in-fabric|not-in-same-zone|fabric-info-not-available}]- Extended Status-
Use this parameter to select the extended result of FCP ping command.
cluster1::> vserver fcp ping-initiator show
Node Logical Ping Extended
Vserver WWPN Name Interface Status Status
vserver_1
c0:03:ff:e4:70:06:00:e4
node_1
lif_1 reachable wwpn-logged-in
c0:03:ff:e4:70:06:00:e6
node_2
lif_2 not-zoned -
2 entries were displayed.
