vserver cifs group-policy show-applied
Show currently applied group policy setting
[-fields <fieldname>,…] -
If you specify the -fields <fieldname>, … parameter, the command only displays the fields that you specify.
[-instance ]} -
If you specify the -instance parameter, the command displays detailed information about all entries.
[-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays only group policy information that has been applied to the Vserver you specify.
[-gpo-index <integer>]- GPO Index-
If you specify this parameter, the command displays only group policy information at gpo-index.
The following example displays all group policy information about all group policies that have been applied to a Vserver:
cluster1::> vserver cifs group-policy show-applied
Vserver: vs1
GPO Name: Default Domain Policy
Level: Domain
Status: enabled
Advanced Audit Settings:
Object Access:
Central Access Policy Staging: failure
Registry Settings:
Refresh Time Interval: 22
Refresh Random Offset: 8
Hash Publication Mode for BranchCache: per-share
Hash Version Support for BranchCache: all-versions
Security Settings:
Event Audit and Event Log:
Audit Logon Events: none
Audit Object Access: success
Log Retention Method: overwrite-as-needed
Max Log Size: 16384
File Security:
/vol1/home
/vol1/dir1
Kerberos:
Max Clock Skew: 5
Max Ticket Age: 10
Max Renew Age: 7
Privilege Rights:
Take Ownership: usr1, usr2
Security Privilege: usr1, usr2
Change Notify: usr1, usr2
Registry Values:
Signing Required: false
Restrict Anonymous:
No enumeration of SAM accounts: true
No enumeration of SAM accounts and shares: false
Restrict anonymous access to shares and named pipes: true
Combined restriction for anonymous user: no-access
Restricted Groups:
gpr1
gpr2
Central Access Policy Settings:
Policies: cap1
cap2
GPO Name: Resultant Set of Policy
Level: RSOP
Object Access:
Registry Settings:
Security Settings:
Max Log Size: 16384
File Security:
/vol1/home
/vol1/dir1
Kerberos:
Max Clock Skew: 5
Max Ticket Age: 10
Max Renew Age: 7
Privilege Rights:
Registry Values:
Restrict Anonymous:
Restricted Groups:
gpr1
gpr2
Policies: cap1
cap2
2 entries were displayed.
