volume efficiency policy create
Create an efficiency policy
The volume efficiency policy create creates an efficiency policy.
-vserver <vserver name>- Vserver-
Specifies the Vserver on which the volume is located.
-policy <text>- Efficiency Policy Name-
This specifies the policy name.
[-type <Efficiency policy type>]- Policy Type-
This specifies the policy type. The policy type defines when the volume using this policy will start processing a changelog. There are two possible values:
thresholdmeans changelog processing occurs when the changelog reaches a certain percentage. -
scheduledmeans changelog processing will be triggered by time.
The default value is
scheduled. -
[-schedule <text>]- Job Schedule Name-
This specifies the job schedule. Use
job schedulecommands to manage job schedules. Only cron job schedules are supported. [-duration <text>]- Duration-
This specifies the duration that an efficiency operation can run (in hours). The possible values are "-" or a number between 1 and 999 inclusive. Default value is "-", which means no duration.
[-start-threshold-percent <percent>]- Threshold Percentage-
The percentage at which the changelog will be processed. The percentage is checked on an hourly basis. The default value is 20. Valid only if
-typeparameter is set asthreshold. [-qos-policy <Efficiency QoS policy>]- QoS Policy-
This specifies how the efficiency operations are throttled. This option can be configured to be
backgroundorbest-effort. Default value isbest-effort. Ifbackgroundis specified, the efficiency operations are run with minimum or no impact on the data serving client operations. Ifbest-effortis specified, the efficiency operations might have some impact on the data serving client operations. [-enabled {true|false}]- Enabled-
This specifies whether the policy is enabled or not. The policy is enabled by default.
[-comment <text>]- Comment-
User specified comment.
The following example creates an efficiency policy.
cluster1::> volume efficiency policy create -vserver vs1 -policy policy1 -schedule daily -duration 100
