ONTAP commands
volume file fingerprint abort
Abort a file fingerprint operation
The volume file fingerprint abort command aborts an in-progress fingerprint operation. This command only aborts the fingerprint operations that have not yet completed. This command takes session-id as input and aborts the fingerprint operation that is associated with that particular session-id.
-session-id <integer> - Session ID of Fingerprint Operation
Specifies the session-id of the fingerprint operation that needs to be aborted. It is an unique identifier for the fingerprint operation. This session-id is returned when the fingerprint operation is started on a file.
The following example aborts the fingerprint operation identified by 17039361 :
cluster1::> volume file fingerprint abort -session-id 17039361
