The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
volume file fingerprint abort
PDF of this doc site
Creating your file...
Your file is ready
Abort a file fingerprint operation
The volume file fingerprint abort
command aborts an in-progress fingerprint operation. This command only aborts the fingerprint operations that have not yet completed. This command takes session-id as input and aborts the fingerprint operation that is associated with that particular session-id.
-session-id <integer>
- Session ID of Fingerprint Operation-
Specifies the session-id of the fingerprint operation that needs to be aborted. It is an unique identifier for the fingerprint operation. This session-id is returned when the fingerprint operation is started on a file.
The following example aborts the fingerprint operation identified by 17039361
cluster1::> volume file fingerprint abort -session-id 17039361
