vserver fcp show
Display FCP service configuration
Displays the current status of the FCP service in a cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Use this parameter to display the FCP services that match the Vserver that you specify.
[-target-name <text>]
- Target Name-
Use this parameter to display the FCP service that matches the target name that you specify.
[-status-admin {down|up}]
- Administrative Status-
Use this parameter to display the FCP services that match the administrative status that you specify.
cluster1::> vserver fcp show Status server Target Name Admin --------- ---------------------------- ------ s0 20:00:00:a0:98:0c:b0:eb up s2 20:01:00:a0:98:0c:b0:eb up entries were displayed.
Displays the FCP configuration for all the Vservers in the cluster.
