storage disk removeowner
Remove disk ownership
The storage disk removeowner command removes ownership from a specified disk. Then disk can then be reassigned to a new owner.
- -disk <disk path name>- Disk Name
This specifies the disk whose ownership is to be removed.
- { [-root <true>]- Root Partition of Root-Data/Root-Data1-Data2 Partitioned Disk (privilege: advanced)
This optional parameter removes ownership of the root partition of a root-data/root-data1-data2 partitioned disk. You cannot use this parameter with disks that are part of a storage pool. The default value is false.
- | [-data <true>]- Data Partition of Root-Data Partitioned Disk (privilege: advanced)
This optional parameter removes ownership of the data partition of a root-data partitioned disk. You cannot use this parameter with a root-data1-data2 partitioned disk or disks that are part of a storage pool. The default value is false.
- | [-data1 <true>]- Data1 Partition of a Root-Data1-Data2 Partitioned Disk (privilege: advanced)
This optional parameter removes ownership of the data1 partition of a root-data1-data2 partitioned disk. You cannot use this parameter with a root-data partitioned disk or disks that are part of a storage pool. The default value is false.
- | [-data2 <true>]- Data2 Partition of a Root-Data1-Data2 Partitioned Disk (privilege: advanced) }
This optional parameter removes ownership of the data2 partition of a root-data1-data2 partitioned disk. You cannot use this parameter with a root-data partitioned disk or disks that are part of a storage pool. The default value is false.
The following example removes the ownership from a disk named 1.1.27.
cluster1::> storage disk removeowner -disk 1.1.27
 PDFs
PDFs
