vserver cifs users-and-groups local-user show-membership
Display local users' membership information
The vserver cifs users-and-groups local-user show-membership command displays the membership of local users.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver
If this parameter is specified, the command displays local user membership information for local users that are associated with the specified Vserver.
[-user-name <CIFS name>] - User Name
If this parameter is specified, the command displays local user membership information for a local user that matches the specified user name.
[-membership <CIFS name>,…​] - Local Group That This User is a Member of
If this parameter is specified, the command displays local user membership information for the local group of which this local user is a member.
The following example displays the membership information of all local users; user "CIFS_SERVER\Administrator" is a member of "BUILTIN\Administrators" group, and "CIFS_SERVER\u1" is a member of "CIFS_SERVER\g1" group.
cluster1::> vserver cifs users-and-groups local-user show-membership
Vserver        User Name                       Membership
vs1            CIFS_SERVER\Administrator       BUILTIN\Administrators
               CIFS_SERVER\u1                  CIFS_SERVER\g1
2 entries were displayed.
